Soon I will be doing a mechanical to electronic speedo swap.
But before I attempt this, I just wanted to ask you guys about the compatibility of clusters.
A guy in UK told me that I need a cluster that has a barcode number matching my original cluster, because if I get the wrong one, it might burn out the wiring?!
My car is a 91 MR2 Turbo.
Originally sold in America and exported to Denmark.
The cluster I will be getting is a UK one.
So I know there is some difference in the gauge setup
(everything has been moved to the opposite side of the cluster).
Will be getting a UK cluster as the LHD cluster's are hard to come by in Denmark.
Ever tried
"burning out" a cluster? in a swap between mechanical and electrical? in a swap between RHD and LHD?
Any heads up's before I do this?
