[Mk2] [Turbo] rev3 turbo stock boost
pcwinks
Post by pcwinks »
Just fitted a mechanical boost gauge to my 95 rev 3.
It is boosting 13 / 14 psi does this seem right?
Car fitted with hks dump valve, apexi induction kit, blue flame exhaust.
Thinking of fitting an mbc what psi should i run safely and would I gain much? Everything else standard :?:
badgerbob
Re: [Mk2] [Turbo] rev3 turbo stock boost
Post by badgerbob »
Sound about right bud :thumleft:
Boost wise I run mine at 1.15 bar (16-17psi) though I'd say that we're your limit without checking things out properly on a dyno :D
badgerbob wrote:Sound about right bud :thumleft:
^ yeah that :)
jasongtr
Post by jasongtr »
really, when i have my blitz ebc turned off i wont see past 11psi
Stock boost on rev3 turbo is 13psi. Fuel cut @ 18.
jasongtr
Post by jasongtr »
ah well, its never turned off much to be honest, usually set at 17-18psi
jasongtr wrote:ah well, its never turned off much to be honest, usually set at 17-18psi
Nah, not a right lot of point fitting a boost controller and switching it off. :mrgreen:
jasongtr
Post by jasongtr »
its turned off if im caught out in the wet, but it seems to only flick flames out when its turn up :mrgreen:
jasongtr wrote:its turned off if im caught out in the wet, but it seems to only flick flames out when its turn up :mrgreen:
Just because it's turned on, it doesn't mean you have to use the boost in the wet! :lol: :mrgreen:
jasongtr
Post by jasongtr »
ah right i didnt realise that :lol:
:lol:
raptor95GTS
Post by raptor95GTS »
is that even possible to not use boost? :shock:
jasongtr
Post by jasongtr »
NAH he's messing around
bobhatton
Post by bobhatton »
That is what the right foot controls
