No, I do not like them and the boot will have the dry sump tank in it.
It will be a large charge cooler system with an ice tank in the boot and front rad
[Mk2] [Turbo] Starting build
Re: [Mk2] [Turbo] Starting build
bobhatton wrote:It will be a large charge cooler system with an ice tank in the boot and front rad
One of the PWR cores or something else?
Re: build
calum4492 wrote:u considered water/meth? i plan on getting some but cant afford it right now
I will not need water injection as the engine has been designed correctly and will not knock.
Water is only needed when an engine is detonating, if it is injected any other time the engine will lose power.
Magic Beans wrote:bobhatton wrote:It will be a large charge cooler system with an ice tank in the boot and front rad
It will not be PWR one, I think it will be a Bell one I get when I find the room to fit it
" Max rev will be around 9000 if the cams will get me there, "
Bob HKS 272 cams run to 9100rpm. If you need more info on them pm me mate.
Mike N wrote:" Max rev will be around 9000 if the cams will get me there, "
Thank you, I have GSC 274 Rev 3 cams so should be ok
J-1 wrote:Any update?
I have just got the block back after a mod or two to it.
Had some work done on the head so I can fit a cam senser, just need the maching work done now.
Need to start the first trial build of the block but the workshop is a bit damp at the moment so not sure I want to start that yet.
Got some new parts.
bobs build
2000cc? or jus a model name?
ur making my 1150's sound like paps
Re: bobs build
calum4492 wrote:2000cc? or jus a model name?
2000 is the model name, they are 2200cc
Re: bobs build
bobhatton wrote:calum4492 wrote:2000cc? or jus a model name?
Lol
Re: bobs build
bobhatton wrote:Got some new parts.
Mind if I ask who you got them through bob and what you paid?
Cheers.
Re: bobs build
Probably idle and run aswell/better than your 1150's too
greeny wrote:bobhatton wrote:Got some new parts.
Image Replaced With URL For Quote http://i744.photobucket.com/albums/xx83 ... 915de0.jpg
Cheers.
I got them from Ty Saxon in the USA, they are new and came with a large fuel rail and -10 fittings. Had been fitted but never used.
I think the cost with shipping was around $950
So what am I doing here and why?
Adding gearing for the dry sump oil pump?
