I knew it had to be an injector fault, i didn't buy the rear overheating cylinder thing for a second, Toyota aren't that daft, just a shame it took out two engines in the process but at least it won't be taking out the new one
charged wrote:Mine's probably screaming'stop raping me'
PW@Woodsport wrote:That's a nice rig Tom, i like that a lot.
pk_090 wrote:Will you be accepting donations for injector testing now Tom?![]()
elbon50 wrote:Presumably No.4 was the faulty one Tom
Was it over fuelling?
Icsunonove wrote:Thanks Gary.I've explained it all to Lauren and it's up to her what to do next.
It doesn't stop the engine rebuild, everything can be done, just means the engine can't be started until the injectors are sorted.
The part number of the injectors fitted are 23250-16010, it has a grey square plug that is different to the pink MR2 injectors I have.
PW@Woodsport wrote:
Does Laurens 86 have a resistor pack Tom? If it does then pink ones will be fine, if not then Mk1a injectors will be the ones to use.
I wrote:.
.The ECU should cope with this change, they are similar impedance.
