Good afternoon All,
The other morning I drove to work in my MR2 the speedo
& milage were working fine.
Parked my car to to do my work rip, then came out 9 hours later started my car
& there was not response from the speedo, after driving a bit down the A500 I noticed that my car was not gaining any miles.
I have had a bit of a look on the internet to find out what could be causing my problem.
Followed some instructions that i have found on here
& other places.
The simple tests i have tried was:-
Giving the dash board a good wack in a few different places, which has no effect.
I have seen a picture of a 3 pin connector that connects the sensor to the gearbox, but i can't seem to find this.
Looking down from the top of the engine bay.
Now i think its down the passenger side of the engine bay by the drop link.
found a connector down there give that a wiggle but that also had no effect
Now i have also been reading that sometime the cable behind the dails is at fault, With mine been a uk spec do they have kph to mph convertor.
Also done a full fuse check there all good? any advice on what i should do next.
The car is stock other than:-
HID H1 lights in the front Splitter
(dont work since the H4s were fitted)
HID H4s dipped/full beams
(when on the indicator on the dsh does not lights/fullbeam)
K
& N 57i induction kit.
Car has a full service history last thing what was changed on the car was the clutch at 127,000.
This is the reason why i have been trying to find this cable in the engine bay, because i think its just fallen off or come loose.
