Exhaust idea...
stephano
Re: Exhaust idea...
Post by stephano »
you'll need to cut the pipe coming off the thermostat housing at a 35-40 deg angle and spin it around so it faces down along the engine.
i cant remember what pipe i used to run from there down under the car tho.
it is touching the silencer on mine but where it is i wraped the pipe in armorflex insulation tape and its not melted and is ok to touch after a blast.
ill try and take some better pics in the next day or so.
this is the best ive got for now.
also did the old man get back to you about the fuel fittings? i gave him a list of what i had to price.
J-1
Re: Exhaust idea...
Post by J-1 »
Noz_13 wrote:
That's quite close to that rubber hose eh?
Would this cause a problem for a track car that'd get constant abuse?
J-1
Re: Exhaust idea...
Post by J-1 »
This was quoting Noz 13's photo on pg2
J-1
Re: Exhaust idea...
Post by J-1 »
stephano wrote:you'll need to cut the pipe coming off the thermostat housing at a 35-40 deg angle and spin it around so it faces down along the engine.
Image Replaced With URL For Quote http://i155.photobucket.com/albums/s311 ... G_0564.jpg
Image Replaced With URL For Quote http://i155.photobucket.com/albums/s311 ... G_0567.jpg
Image Replaced With URL For Quote http://i155.photobucket.com/albums/s311 ... G_0568.jpg
Image Replaced With URL For Quote http://i155.photobucket.com/albums/s311 ... 237715.jpg
Need as much info on the exhaust as possible as soon as possible, please.
Where would I get that insulation tape?
J-1
Re: Exhaust idea...
Post by J-1 »
http://www.ebay.co.uk/itm/Jetex-Univers ... 2ebb3426b9
A bit shorter at 250mm but would it be quiet enough???
Burns Stainless stuff looks excellent!
http://www.burnsstainless.com/sm-300-450-12.aspx
J-1
Re: Exhaust idea...
Post by J-1 »
bobhatton
Re: Exhaust idea...
Post by bobhatton »
In round figures its about £250 for the fittings and hose depending on size and filters etc.
stephano
Re: Exhaust idea...
Post by stephano »
heres some pics i took tonite
this is the bit that needs cutting and spining
this is where it touches the silencer. looks like i used the bit of insulation already on the pipe. but if you need some this should be better than what im using. http://www.pipelagging.com/armaflex-sol ... 55_63.html
i think its a stock pipe i used but not sure if its the one from there origonaly you may need to get a 1m length of silicone hose instead
where it joins onto the pipe from under the car
not easy to see but its from underneath
through the side vent.
J-1
Re: Exhaust idea...
Post by J-1 »
Thanks mate. I've sent these to my exhaust builder! 8)
