hi all ive brought a mr2 as a none runner for a project.but stuck on this, as i turn the key nothing happens.all the dash lights come on and all electrics work just cant think of anything else.
rob
[Mk2] [Turbo] turn key and nothing
Re: [Mk2] [Turbo] turn key and nothing
no1 got any ideas
Starter relay is a possibility. Might need cleaning. I used to have a car that did it, quick turn of the key off and on a few times helped to clean the contacts.
thanks for that i will give that a try
still no luck
get someone to listen by the starter motor and see if its clicking when yuo turn the key.
Could be the starter moter is jammed if its been stood there a while or even goosed.
I take it you have got a fully charged battery as well?
battery is fully charged.we have put power to started motor and it spins up.
any info from the previous owner of what happened before it became a non starter?
any immobilser fitted that he never told you about
Can you turn the engine over by hand to see if it isnt seized
all the old owner said he was driving out of his street and it just died.
not tried to turn it over by hand.how do i do that?
hmmmm dont sound like a seized engine then and wont be anything to do with the starter motor.
Going to be some kind of electrical gremlin. Could be a dodgy corroded earth. There are loads of these.
Gearbox to chassis, frunk battery terminal and under the inlet mainifold are a few of them.
I aint really all that clued up on the electrics side if things though
You tried bump starting it?
have tried that but were not getting a spark either
No spark? Have you got fuel pump going and injector pulse?
Sounds like it could be the igniter? Try swapping in a known working igniter+coil and see if that helps?
