Bottom ball joint spacer
mulaz
Post by mulaz »
Stripping down front suspension to fit new poly bushes,
found one thin spacer packing piece under the offside ball joint and none under the nearside.
i remember reading the MrT fitted the odd pack piece when building up the cars.
going to have a 4 wheel alignment done afterwards so should i refit the packing when i build up the suspension or leave it out?
un1eash
Re: Bottom ball joint spacer
Post by un1eash »
Some have them, some dont. I left mine out as they had rusted badly.
mulaz
Post by mulaz »
Cheers for the info
will leave it out as it is badly rusted :thumleft:
boondougal
Post by boondougal »
I posted about this a few days ago.
I just left it out
PW@Woodsport
Post by PW@Woodsport »
I believe it's there to counter the weight of the driver, as it's always the OSF that it's fitted to it seems, best guess.
un1eash
Post by un1eash »
PW@Woodsport wrote:I believe it's there to counter the weight of the driver, as it's always the OSF that it's fitted to it seems, best guess.
I was guessing something along these lines, or they realised last minute it something was of slightly so fitted it to balance things out.
