Cambelt
Oil
Oil Filter
My mind has gone blank and i'm reusing the exhaust manifold gasket and flywheel bolts.
Anything else let me know.
charged wrote:Mine's probably screaming'stop raping me'
kaiowas wrote:There's very little that you*need* but a few things that it's useful to replace whilst the engine is out simply because it's easier.
You've already mentioned the cambelt, whilst the belt is off it's often worth looking into the belt tensioner and water pump, particularly if the engine is an unknown quantity.
If your thermostat is old then now might be a good time to replace it whilst the coolant is drained and the pipework is readily accessible.
Technically various gaskets and seals should be replaced whenever they are disturbed but most of the time you can get away with reusing them.One which springs to mind that hasn't been mentioned is the copper crush washers for the oil cooler fittings although personally I reuse them it's a matter of how thorough you feel like being.
Although Kevin mentioned clutch fluid I personally don't break into the clutch hydraulic circuit when dropping the engine.I find that unclipping the shift cables from the bracket at the gearbox end gives sufficent movement to allow you to hang the bracket out of the way with the hose to the slave cylinder still connected.
Having said that, if the slave cylinder is showing any sign of leaking
(a common fault) then it might be worth swapping it out whilst everything is in bits.
SuperRedMR2 wrote:I'm currently not running any on the manifold to downpipe as I didn't have any when I last put the downpipe on but will get some this time.
SuperRedMR2 wrote:I drove the MR2 this morning- I feel that I could love it once again.
The exhaust is mega quiet at idle but sounds very nice when on the throttle.
kevin..in wrote:you will be doing well if you can re use the exhaust manifold gasket, i'd get a new one for what they cost, its a PITA to have to re do a blowing one next week
Lauren wrote:kevin..in wrote:you will be doing well if you can re use the exhaust manifold gasket, i'd get a new one for what they cost, its a PITA to have to re do a blowing one next week
On my car(same gasket) I've had the manifold on and off at least 5 times, would have thought it fine to re-use it, though it's crap to get to on an MR2.
I would replace the rings for the downpipe, however.![]()
Lauren wrote:Fair play, Kevin.Just saying I've had mine on and off at least 5 times without issue.
My manifold is a lot easier to get at however.
kevin..in wrote:your engine is back to front innit![]()
Lauren wrote:kevin..in wrote:your engine is back to front innit![]()
LOL!
The 4AGE was designed for my car, so I don't think it could be back to front.![]()
/touche!
