Cooling system cleaner..?
Amebb
Post by Amebb »
hi
can anyone help me on this one.... I found lots of brown depositis in my cooling system.
I need to give the cooling system a good clean out before topping it with antifreeze etc...
Can anyone recommmed a good cleaning product that can loosen the crap from my cooling system...?
Thank you
'Honest, seriously, this wont hurt a bit ..... there you go........ 5h1t!!! he's dead!!........ Well, you should'nt have touched my Mr2 !!'
Ekona
Re: Cooling system cleaner..?
Post by Ekona »
Theoretically something from the Fernox range would work, but you want to make sure that every last drop was out before re-filling. I'm sure there's an auto-specific product out there.
Amebb
hi
Post by Amebb »
i was thinking of going to the local plumbers merchants and getting something that cleans radiators at home and it also protects them against rust.....
thanks
frogger
Post by frogger »
Cheap and effective way is pressure washer in one end, open end at 'tother - and just flow a shed load of water through the system and out.
Don't start adding non-compatible rust inhibitors to your coolent system :)
P.S. the above is largely pointless if you have a cheap/corroded radiator sitting there ready to carry on adding crud into the system
Return to “MR2 MK3 2000-2007”
