Mr2 Mk2 Rev3 GTS Twin entry Turbo Import 1994 in Red
Hard top tin roof
88k Miles
Central locking
Power steering
Pioneer bluetooth cd player with remote, plays mp3 cds also
subwoofer behind the passenger seat
Amp
Spare wheel
Toyota tools
Original toyota Mr2 manual
2 keys
Air con
Foglights uk compliant
UK legal front lenses
Cloth seats
Changed the ignition ring light to blue led
Changed the speedometer bulbs to blue leds
Staggered alloys 18inch on the back and 17inch on the front
CD cubby between passenger and drivers seat
Only shell vpower or tesco momentum premium petrol used
Electric mirrors
Electric windows
New premium pilkington windscreen, crystal clear.
Authentic japanese flare
MOT June 2012
Tax 31/07/2012
I have all the paper work for work carried out and and all the import certificates etc.
Never had a problem with cold starts etc, always let the turbo idle before turning off the car.
The work I have had done to the engine has been with Rogue motorsport, an Mr2 specialist.
Coolant leak fixed 03/12/2009
Core plug replaced 03/12/2009
New battery 11/11/2009
Clutch replaced 2010
Rear repeater bulbs replaced 16/10/2010
Handbrake cable replaced 09/03/2011
OEM BOV replaced 28/03/2011
Electric Automatic Aerial motor replaced 28/03/2011
Cambelt changed
Idler bearings upgraded 21/03/2011
Water pump changed 21/03/2011
Interior light bulbs changed
As you can see I have spent over
I want to be as honest as possible, the bad points are all associated with the exterior paint work.
Bad points(all shown in the pictures):
Front bumper has some cracks on the bottom lip with some bubbling above the plate
The trim is missing near the side repeaters
I had the bonnet touched up so it is an ever so slightly darker shade, the rest of the car is original paintwork so has faded somewhat in comparison.
The rear bumper has faded paint on the edge of one corner
On the drivers door along a small bit of the edge the paint has degraded away and there is a slight bit of rust.
Engine lid has a couple of light scratches
Rear tyres could do with replacing
There is one other thing, the clutch may squeek at times when being pressed, this merely needs oiling.
Well I just copy pasted from my pistonheads advert, I'm sure everyone here knows everything about mr2s hopefully I've priced it correctly.
The fastest response will be through my email, [email protected]
