The wheels are 5x114 PCD, 16" and look similar to stock Rev 2/3/4 SW20 wheels.
Has anyone seen these fitted to an MR2?
[Mk2] [Generic] Fitting Nissan S14 200SX alloys?
Re: [Mk2] [Generic] Fitting Nissan S14 200SX alloys?
Peter Gidden - SBITS wrote:Offsets?
PCD - 5x114
Offset - 35 to 42
Bore - 66.1
That's fairly close to MR2 dims, isn't it?
I assume I would need 20mm spacers on the rear?
You wouldn't need spacers. Stock MK2 Offset is +45.
Bore size of wheels is oversize though, so you'd need spigot rings to reduce to 60.1.
What's the width also?
6.5" all round
considered fitting them once upon a time but not wide enough for the rear
Wouldn't a 225 section tyre fit on a 6.5" rim?
it would be a stretch, most tyre manufacturers recommend 7" - 8.5" for a 225/45/16 with 7.5" being optimum
Got a picture of a mk2 on S14 alloys somewhere, shall try dig it out.
mates got them on his na
ill take some pics the weekend for you
