I've used the search function but not really found what I was after.
So thought I'd ask the experts
I have a rev 2 Turbo
(not sure if that makes a difference) and this is what I'm after.
a S/S twin exit exhaust that is not massively loud.
Also, with tail pipes that are pretty much of stock width
(perhaps a little bit larger but definitely not big bore tail pipes that stand out).
In a perfect world it would also have a singe can from which the two pipes emerge if that makes sense
(see the image below) rather than two separate pipes and two separate cans.
In fact the exhaust below looks pretty much exactly what I am after but I'm guessing a TRD exhaust would be mighty expensive and not the easiest thing to get hold of!
http://www.google.co.uk/imgres?q=mr2+tu ... 60&bih=591
In the absence of getting hold of the above I have seen the mongoose is fairly close to what I'm after
(even though it has separate pipes).
Are there any other options matching what I am after?
Question 2.
I am also after a decat.
Would any decat for a Rev2 fit any exhaust or would I have to match up accordingly
(e.g.
blitz decat with blitz exhaust)?
One final question.
will only a rev 2 turbo exhaust fit on a rev 2 or would rev 1, rev 3 etc all fit?
Thanks in advance guys!
