The plan is to keep everything as close to the original spec as possible but just add a few things here and there to modernise it a bit.
This is the car as i first got it and the only thing i did was stick some nice 15" wheels on it, Yoko tyres and drop the suspension 30mm.
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport4/DSCN1107.jpg)
I added some screaming chickens to the wheels instead of the centre caps they came with, which i didn't like that much.
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport4/DSCN1113.jpg)
I want to replace the engine and gearbox with something different but still along the same lines, so i bought a Celica 6 speed, took out its internals, and swapped them into a Mk1 bellhousing case, i also fitted a Mk3 Mr2 Torsen LSD unit and installed the Mk3 6th gear set for a nicer top end.
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport4/IMG_0211.jpg)
Engine wise i've taken a stock 7 rib block, overbored it 0.5mm and had it decked.
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport4/DSCN1128.jpg)
The crank has been balanced and lightened.
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport%205/DSCN1252.jpg)
New Toyota big end and main bearings fitted, sized correctly to each journal and double checked with plastigauge.
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport%205/DSCN1254.jpg)
Piston rings all gapped and new oversize pistons installed.
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport%205/DSCN1258.jpg)
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport%205/DSCN1260.jpg)
New oil pump installed.
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport%205/DSCN1302.jpg)
ARP headstuds fitted and HKS 2.0mm gasket.
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport%205/DSCN1305.jpg)
Every nut and bolt renewed along the way, i haven't reused a single bolt at this point, new water pump fitted.
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport%205/DSCN1301.jpg)
Valves lapped into the freshly skimmed head and all torqued down, i've added some adjustable alloy cam sprockets and a Zaklee clear timing belt cover along with a one piece alloy crank pulley.
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport%205/DSCN1556.jpg)
Exhaust is being taken care of by a 4-2-1 tubular manifold.
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport%205/DSCN1558.jpg)
The plan is to add a dollop of forced induction to this engine with a TRD Scion supercharger unit, i am going to run a USDM EFI system with AFM, Lexus LS400 V8 injectors
Meanwhile back on the car i fitted some JDM rear lights and added our name to the rear visor in the same font Toyota use.
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport4/DSCN1134.jpg)
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport4/DSCN1129.jpg)
Made my own JDM LED spoiler using the light from a Windom, which is practically identical, i grafted the housing into the Mk1 spoiler so the LED unbolts as it normally would.
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport4/DSCN1138.jpg)
![Image](http://img.photobucket.com/albums/v624/paddy1970/Woodsport%205/IMG_0235.jpg)
Nothing else i want to do bodywise now, i also added a SC engine lid too.
I'll update the thread as the other mods develop, this car is also going to get my adjustable power steering upgrade too.
