I've parted with £60 and £84 for pattern part clutches, one lasted 25k and the other 35k and disintegrated in spectacular fashion.
I just want to buy a clutch that is going to last a few years.
Stupid Question Time
Re: Stupid Question Time
Lauren wrote:
It's an absolute urban myth that's it's a copy of the BDA. Sure stroke and bore may be the same and it's got twin cams and 16v's but that's about it.
Edit: didn't see Jimi's post.
BDA manifolds fit the Yam designed head without modification, so I'm reliably informed
Peter
AW10 used a 3A-LU which I believe was all Toyota designed.
Toyota and Yamaha have a long history of collaboration on engines, starting with the Toyota 2000GT in the 1960's and among others the 4A-GE (including the Formula Atlantic engines), 3S-GE/GTE and 2ZZ-GE, 1LR-GUE (ISF/LFA) and probably a lot more that I'm not aware of
Well I'm much better informed now. Thank you all
I like to drag such issues out into the daylight
I apologize, seem to have hi-jacked Super Red's thread
You just want a reliable clutch then SR, not a high performance engine ?
In that case is ali flywheel the best move I wonder ?
Peter
Peter
Turned out not to be such a silly question after all then.
The flywheel is being purchased for a direct replacement for my mullered existing one.
I dont want a high performance engine as this is my daily driver - If I did id buy an Evo or a Supra
As I see it, a light flywheel is a performance mod
Will allow the engine to rev more freely, thus stressing the clutch even more
What is supposedly wrong with your current flywheel ?
Why not have it balanced, together with a new genuine Toyota clutch ?
Or get another standard one & have it & the new clutch balanced ready before you start to remove the g'box
Peter
Peter
My flywheel has been described as the grand canyon, due to my stupidity in my earlier years of dropping the clutch and I had been told ages ago that a lightened flywheel was one of the best mods you can get, so that is why.
My engine has been fully rebuilt by Rogue Motorsport so I thought I'd compliment the engine with a lightened flywheel. I am also getting a good discount from Twosrus which is helping out two fellow members.
I'm not interested in a standard clutch as I am fed up of the car breaking down in shitty weather and having to take the car apart in the freezing cold weather. I'd rather buy a good one and not have to worry for a few years. I am now suffering from torn neck ligaments which makes working on the car in that area even more painful.
But back to my original question, I'll probably get the flywheel balanced and thanks for everyones advice!
Yes its not a small job to change the clutch on a Mk1. I changed my g'box last year so I know a bit about that
This is certainly a better time of year to do the job than in a bitter cold Winter like the last one
Good luck with it
Peter
- Lauren
- IMOC Committee
Be careful what you buy because paddle clutches and the like will make daily driving in traffic a real PITA.
An OEM clutch is good. A pattern one is not so good. You get what you pay for.
Exedy clutch kit:
http://cgi.ebay.co.uk/EXEDY-CLUTCH-KIT- ... 3876wt_921
2020 GR Yaris - Circuit Pack
Thats 200mm Lauren, I have found that exedy dont do many clutches for the mk1b
Exedy clutch kit:
I doubt that clutch is made by Exedy. The majority of 'road spec' clutches are identical, the company buys them in in bulk and puts their name on them. You are paying extra for the name. This means that quality can vary hugely batch to batch and you're no better off than buying the cheap one from the motor factors!
Exedy used to make them for everyone else
I'd personally go for an uprated organic, not an OEM. should feel the same and last longer.
Cheers Tim
Your best bet is to ring exedy and ask for the uprated organic, they will then tell youn a supplier, they wont be cheap.
Take note that a lot of the organic ones for sale are not the uprated organic.
I think the part numbers you want are (my records are old so please double check them first):
cover: TC03T
uorated organic disc: TD03H
bearing: BRG441
cover: TC03T
bearing: BRG441
