I wouldn't bother faffing around with creating some kind of 3ZZ hybrid
(and I know there's a proper 3ZZ before anyone picks up on that
), it's not a proven solution as the guys in the US will testify to.
Far better to leave the 2ZZ stock apart from some cryo'd lift bolts as they're a weak link, then stick a PFC or similar on and tune it for a reliable 200bhp-ish.
IIRC engine mounts will need altering along with a new manifold, ECU can be done but far better to just go PFC.
You won't want the 5-speed
'box as the ratios are all wrong for staying in lift, the 6-speed
'box is what you need.
You'll also need to make alterations to the wiring loom and the dipstick.
