I guess its ok if you dont drive the car that much or dont mind changing sparkplugs with your oil.
The standard plugs for a tubby are platinums NGK BKR6EP-8.
I'm going to try out a set of NGK PFR7B which are the newer style colder grade platinum plugs.
I'm hoping they will work well fingers crossed.
Edit: never mind you've got an na.
Dunno whats better for those, I ran plats in mine but that was ages ago.
