LSD for 4A-GE?
kaiowas
Re: LSD for 4A-GE?
Post by kaiowas »
LSDs for any Gen 7 Celica/Elise which uses a C-series box ought to be fully compatible with the MR2 C-series and will mostl likely be more freely available.
cartledge_uk
Re: LSD for 4A-GE?
Post by cartledge_uk »
Also the yaris/vitz (i think)
aw11rally
Re: LSD for 4A-GE?
Post by aw11rally »
elise/celica lsd has larger output splines for half shafts therefore not compatible.
rexer200
Re: LSD for 4A-GE?
Post by rexer200 »
Just a thought, I've read some where that all UK MK3's come with LSD's as standard, so wouldn't it be possible to swap the bell housings on the gearbox over, and fit to a Mk1?
I think then all I'd need is Mk2 N/A shafts - is this correct?
cartledge_uk
Re: LSD for 4A-GE?
Check part numbers on here
http://www.nengun.com/trd/limited-slip- ... al-helical
But
There are a few on ebay at the moment :wink:
search EP82 trd lsd
