Pictures and Ebay Listing:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0379046860
This has been my weekend toy since Feb 2006, bought the car with just over 45k on the clock.
At the start of the year the car was converted to run a Celica GT4 205 chargecooler instead of the original side mount intercooler using OEM new Toyota parts.
Has run some very fast times at Santa Pod 13.3
Overall the car has been very reliable and has been maintained on a regular basis, have done a few trackdays in the car and it has been faultless, always change the oil
The car is always warmed up and cooled down properly after each drive which is essential with turbo cars.
JVC headunit
Sony Speakers all round.
TRD Gear knob
Short-shifter kit with drop plate
SBITS Shifter bearing kit
HKS SSQV blow off valve
HKS Hiper Exhaust
Decat
ST205 Charge cooler conversion with AVT Bosch high flow pump.
16 inch A-Tech 2 forged alloy wheels
Avon ZZ3 Tires all round covered less than 2000 miles loads of tread left.
Blitz Full auto Turbo timer.
Greddy Profec B spec 2 Electronic boost controller
xxxx FCD
Speed delimited fitted.
Seats from TRD Spider.
Aftermarket wheel,
Smoked Black front side lights
Crystal Headlamp units with Phillips Daybreaker bulbs
Ohlins Adjustable shocks
Cusco Brake Stopper
Hel Braided Brake lines
Drilled and Grooved brake discs
Fast road front pads, EBC Greenstuff rear pads
Apexi Power Intake with rain shield(spare filter included)
Silicone Turbo hose kit in Blue
Silicone breather hoses
Aftermarket Front and Rear Strut braces
Oil and filter and spark plugs changed every 3000 miles
New clutch slave and master cylinder less than 200 miles ago
New radiator and coolant hoses fitted less than 500 miles ago
New Lambda sensor less than 500 miles ago
New oil filter
New fuel filter
New cold start sensor
First of all this is a 1992 car so there are the usual stone chips and small marks.
The original plan was to fit some subtle side skirts to hide the defects but due to moving house i need a more practical car.
Overall the condition of the car inside and out is very good, i have tried to be as honest as possible and have included pictures of the bad bits, if you require more pictures or would like more information please email me.
I am open so sensible offers obviously as there are a few bits that need attention.
Si
