17x9j
offset 42
stud diameter 114x5
center bore 67.1mm
tyres on them are 255's all round
will these wheels fit?
Re: will these wheels fit?
assuming 40 profiles
http://mr2.gordaen.com/wt_calc.php
MR2 (mkii) Flushness:
Your proposed front wheel will be 6.05 mm farther out than flush (flush offset: 48.05).
Your proposed front is 14.05 mm into the suspension!
Your proposed rear wheel will be 6.65 mm tucked in from flush (flush offset: 35.35).
To wide for the front i'm afraid
too wide at the front, and you will need spigot rings too as the MR2 centre bore is 60.1mm
cheers folks, i'll knock that idea on the head then
I had the same problem, got some custom spigot rings made by www.customspigotrings.co.uk which were a bonus, sadly they only do the high impact plastic versions and not the alloy ones as yet, that being said, I have been advised against alloy spigots due to them corroding.
Least the wheels are on and no wobble anymore.
