OK, Ive had a work with one of the experts at work and he pretty much agreed with whats already been said.
He recommended that its not generally a good idea to trade boost for CR as you end up taking out a lot of MAP to compensate for a small change in CR.
Also, sensible targets for CR are often taken from benchmarking existing engine designs as its very hard to predict knock limits.
He also said that you normally define the performance you want, then increase the CR to the point at which you have to retard timing and/or use significant fuel cooling to protect from knock.
(This is where I think you might be going with your plans but the CR change could be minimal)
Some key points to remember are:
Typically 1CR
= 2-4% fuel economy gain.
In cylinder temps are one of the main drivers for knock limit.
Combustion chamber design also affects knock but since were dealing with the same design for both set-ups then we can
(roughly) estimate knock limit by working out peak in-cylinder temps.
Combustion temps increase with CR from extra charge compression, but also because the combustion process occurs faster with higher CR
Based on that, it sounds like estimate peak temps using gas laws is worth doing.
Without checking the numbers, I think thats what youve already done but remember that the process isnt isentropic so the real temps will be higher than youre predicting.
This will be the case for both low
& high CR variants but probably more so for the high CR engine as its doing more work, hence will be further from an
ideal process.
Also, the peak temps for the high CR engine will be worse still due to the combustion occurring faster.
Unfortunately I dont have a grasp on how much worse so for now well have to leave this out of the calcs and just bear it in mind.
The trouble with your example is that
(unless you know otherwise) there is nothing to say that the engine is running maximum possible boost.
Ive heard of 2bar boost or more, but I havent seen that first hand so dont know how effective that is, or what charge temps its combined with.
I think the best thing to do would be to identify an engine with a known CR, IAT and MAP thats running on the knock limit.
It would then be possible to use that to setup a baseline and compare its peak temps to a high CR version of the same engine.
The important thing is to consider
knock limit as the point at which ignition/fuelling needs to be used to protect from knock, at the expense of power.
That means that the engine cant be one running a huge amount of boost and using the ignition map/fuelling to survive.
Using some real engine data would be best but some quick calcs could be done to work through the temps assuming
Turbo
Intercooler
Compression for a few different options and see what comes out as a likely MAP compensation for different CR increases?
Have you already done this?
Wingers
