I have been in contact with BC racing
Front Coilovers
Front Spring Rate
Rear Coilovers
Rear Spring Rate
The BR series coilovers use a large 44mm diameter piston in a 53mm diameter damper body to maximise oil capacity.
BC Racing only use a very high quality oil with their coilovers but go that extra mile to maximise performance and build their BR range with a large 53mm diameter damper body.
Front Coilovers
Front Spring Rate
Rear Coilovers
Rear Spring Rate
The BC Racing RM series feature high quality damping adjustable monotube inverted dampers at the front or front and rear, depending on vehicle.
Unsprung weight is reduced by moving the oil and gas reservoir way from the hub and attaching it to the shell.
BC Racings current RRP pricing structure stands at
TYPE RA
RM SERIES INVERTED
Delivery should be around
I need to gauge enough intrest in 5 sets of each type to get a good price sorted out.
I will be trying to arrange a 10-15% discount over the RRP printed above
I will update this with prices as soon as i find out.
Thanks Steven
Momentum
