[Mk2] [Turbo] Rev 3 wiring conversion?
kev_mr2
Re: [Mk2] [Turbo] Rev 3 wiring conversion?
Post by kev_mr2 »
so if i was to go down that route id need to change the injectors for say 800cc ones and then the pressure regulator aswell?
once i have done that i will then have to get something to control the injectors? Power FC or the SAFC or whatever it is?
i was cosidering using the Power FC but im gonna stick with the Rev3 ECU and setup just to get used to the big change over standard BHP figures
tarmac terrorist
Post by tarmac terrorist »
mine runs 800cc with power fc you dont need the fpr thou
kev_mr2
Post by kev_mr2 »
cool
im hoping to get around 300 to 320 hp. would the standard rev 3 stuff cope at that?
tarmac terrorist
i thgnk it should be possible i got 355 flywheel when i was running standard rev2 ecu 440 injectors with hybrid ct26 & forged pistons
kev_mr2
Post by kev_mr2 »
hmmm i already have the CT26 hybrid and aload of other mods. not got forged pistons i dont think. any way of checking this?
what sort of pressure were you running at to acheive that figure?
tarmac terrorist
i was running 1.3bar ,im not shore the easiest way to check the pistons mate
kev_mr2
Post by kev_mr2 »
blody hell. im only looking to run 1.1 or so lol
maybe got my hands on a rev3 shell. uk model though. will wiring just be plug and play and no pin swaps?
tarmac terrorist
couldnt tell you on that one mate im affraid
kev_mr2
Post by kev_mr2 »
no worries mate
just had a peek and my pistons have "2E" stamped on them and are a funny shape lol
tarmac terrorist
2e sounds like the standard toyota stamp on them to me it normally determines there size
kev_mr2
Post by kev_mr2 »
so with my list of mods on this engine, do you think i should acheive the 300 mark quite easilly?
Rev3 ECU and fuelling setup obv
CT26 Hybrid (i think its the 48mm compressor wheel) if i set it to 1.1 or 1.2 bar
induction kit
Uprated intecooler
Blitz decat and turbo elbow into a 3 1/2" exhaust
Grade 7 plugs and KV85 leads
tarmac terrorist
i think it should be possible mate, before you start raising boost just get it on a dyno to check you fuelings ok,WARNING at some point thou if you have a standard rev 2 headgasket it will let go, the more boost you put through it the sooner it will go
kev_mr2
Post by kev_mr2 »
yeah the plan is to have it mapped and well ran in before doing so!
i aint taking any chances with it. The head is off and away getting ground along with the block so i have a super smoth surface for the steel gasket to go on
yeah i have ARP head studs which i removed from my last build that went wrong due to tensioner failure. I used a cometic MLS gasket on that.
Im going to get another one of these gaskets but should i retain the standard thickness or go for a 1.2 mm?
tarmac terrorist
the thicker the head gasket the more boost you can run but the less torque you may have lower down,(due to lower compression) although with the head & block face shouldnt be much different from standard i would go with the 1.2mm should be fine thats what i used to run, i now run a 1.6mm HKS
kev_mr2
Post by kev_mr2 »
ok turns out that the engine is a rev1 instead of a rev 2.
does this make it any easier/more difficult?
kev_mr2
Post by kev_mr2 »
Got the Rev3 engine loom yesterday.
was comparing the differences today and noticed that some of the plugs are different on the Rev3 loom compared to the Rev 1 loom. Fuel pump relay one and 1 or 2 others. can i just swap these plugs over from my rev1 loom?
also the rev3 loom doesnt have a single connector that goes to one of the sensors on the water housing connected to the head, is this needed as the rev 1 loom had it
