K Reg Black MR2 T-bar G-limited Rev2 with Rev2 turbo engine conversion.
12 month MOT and taxed until the end of April.
The car has 135k on the clock, as far as I know a lot of that is KM from when it was imported from Japan in 1998 and pretty much most of the car has been replaced since.
The engine conversion was done at 120k by Luke aka skywalker and the engine has now done 57k miles.
The Mods
16 alloys which were professionally repainted nearly 3 years ago just after I bought the car.
Koni adjustable shocks.
Aftermarket clutch which has done 15k.
Departure 2 regular exhaust, the flexi section of the exhaust was replaced with SS flexi, the rest of the exhaust was welded up and painted in high temp silver.
Decated.
Blitz induction kit.
Border rear spats.
Nardi steering wheel.
The rear disks and pads were replaced about 2k ago.
Manual boost controller set to 14psi.
Boost gauge.
Oil Temp gauge.
Cat1 Alarm.
Radiator replaced when the engine was done also with Toyota red for life coolant.
Heater hoses from hell were bypassed due to them leaking.
The drivers side sill was replaced for the MOT.
The bad bits.
Unfortunately these cars are never perfect so heres a list of a few things.
The front Anti roll bars are knocking despite only replacing all 4 a year ago.
The bushes could do with replacing at some point, this maybe reduced the front ARBs lifespan.
The aircon does not work, I replaced the front aircon radiator as that was leaking but then found another leak, every time it gets warm enough to want to fix it it gets cool again
The main and last
Some Pics
Before the Dep2
With the Dep2
Some of the welding on the Dep2
Sorry for the low quality, it was on my phone
