It pretty much as my rev2 turbo except for the following was connected on mine;
EVP
- canister purge solenoid
VTA2
- traction control TPS
(tied to VC)
THG
- as discussed, used for THE
TE2
- test connector
IDL2
(tied to gnd)
PS
- power steering
PSCT
- power steering
ABS
- ABS ecu
(no idea why as this is not present)
CCO
- catalytic converter temp sensor
ECO
- a/c economy mode switch
I think that the TE2 should be connected and THG tied to gnd.
The rest probably do not matter for your GT4 as I found some old notes which did not show them being connected for the Celica.
