hi all
i have a rev 1 turbo i need to change the clutch i was wondering if you have to drop the engine 1 side a little. Or after you have removed everything to get access (my mr2 cd for the computer helps!! ) can you do it all with just the front and rear engine mounts removed (not either side)
any help would be welcomed.
cheers shane
p.s i know there is a lot of other bits to remove but i just want to know if you have to drop the engine (cd does not help with that bit)
fitting a clutch!!!!!!
Re: fitting a clutch!!!!!!
no dont drop the engine , remove the rear subframe that makes it easer,
ps get help lifting it , its dam heavy
