Speaker fitment / Wiring diagrams. please contribute!
Goto page 1, 2, 3, 4, 5  Next
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> ICE and Security
Author Message
Neil_turbo
1987 Toyota MR2 Mk1.5 Turbo
PostPosted: Fri Aug 25, 2006 7:18 am    Post subject: Speaker fitment / Wiring diagrams. please contribute! Reply with quote Reply with quote including images
Ok,
So most of the posts in this section are regards to fitment of component speakers, which ones require spacers, and which dont. I think its about time that we made a collective list of what we have installed, and how many mm's of spacing were needed, eg 2 x 18mm mdf = 36 etc.
I will then keep this list updated and get a photo how-to added. hopefully it can be made a sticky and will be of great help to those changing/uprating their speakers.
But for this to work everbody needs to reply here with what they have and what spacers were needed!
Neil
Back to top
User is offline
Neil_turbo
PostPosted: Fri Aug 25, 2006 7:18 am    Post subject: Reply with quote Reply with quote including images
MK2.............
Front..........
5"...
Focal Poly Kevlar 130K - straight swap. Tweeters needed casing cutting down to fit inside tweeter location.
5.25"...
Helix HXS235 - 12mm spacer
5.5"...
6"...
Oz Audio Matrix Elite 6" Components - approx 1" spacer, tweeters unsure
6.5"...
6.5" DLS R6A -15mm spacers, Tweeters straight swap.
Focal Access 165 - 18mm Spacers, Tweeters straight swap.
Focal k2's 165mm - 11mm Spacers, Tweeters straight swap.
Infinity Kappa components 165mm - straight swap, Tweeters straight swap
Infinity Reference - 24mm spacers, Tweeters straight swap
Helix RS6.3 - 36mm spacers, Tweeters no chance!
Image Dynamics CX62 - 36mm spacers (mid-bass units)
Rear..........
infinity reference 3.5" - straight swap
infinity reference 5.25" - hacksaw!
kicker K35 3.5" coaxials
mac audio 3.5" coaxials, fit in two of the four holes
MK2 Sub Boxes..........
Alpine SWR-1022D/1042D (old type r, white face) - Yes
Diamond Audio D6
Diamond Audio M3101.8 10"
DLS W310B - Will fit, but only reccommmended for ported enclosures of 1.2CuFeet
Infinity Ref 1040W 10" - Yes
JBL GT4-10
JL 10W1V2 - Yes (some JL baskets maybe smaller than 10", please specify if you want a smaller hole when ordering!)
MTX Thunder 5500 10" Yes
Phase Linear Aliante 10SI - Yes
pheonix gold octane ZR10D2 - Yes
phoenix gold xenon 10" 10d2 - Yes (remove rubber magnet cover)
Rockford Punch Stage 3 P310D2/D4 - Yes
Sony Xplod XS-L101P5S - Yes
Vibe PT-100 - Yes
Require 18mm deeper boxes
Alpine SWR-1022D/1044D (new type r, black face)
Sony X-Plod XS-L121P5S 12"
Require 36mm deeper boxes
Audiobahn AW1206T 12"
MK2 Wiring Colours..........
A1 Light Green - Front right (+)
A2 Pink - Front left (+)
A3 Grey - Ignition Switch
A4 Blue Green - Battery
A5 Blue - Front right (-)
A6 Purple - Front left (-)
A7 Brown - Earth (Ground)
A8 Pink Blue - Antenna (power control)
A9 Black Red - Amplifier (power control)
A10 Green - Dimmer
B1 Red - Rear right (+)
B2 Black - Rear left speaker (+)
B3 White - Rear right (-)
B6 Yellow - Rear left speaker (-)
Wiring Diagram For Premium System with 1 Sub (UK & European+Aussie)
MK1.............
Front..........
Rear..........
MK1 Sub Boxes..........
Phase Linear Alliante 10si
MK1 Wiring Colours..........
Front left +ve : Pink, Red dash
Front left –ve : Purple
Front right +ve : Light Green, Red dash
Front right –ve : Blue
Rear left +ve : Black, Red dash
Rear left –ve : Yellow, Red dash
Rear right +ve : Red, Blue dash
Rear right –ve :White, Red dash
Constant supply : Blue, Yellow stripe, Red dash
Switched supply : Grey, Red dash
Earth : Brown
Lights : Dark green
Ariel : (2 wires on car both connected to same radio wire)
a) Black, Red stripe, Red dash
b) Pink, Blue stripe, Red dash
Back to top
User is offline
sadgav
Guest
PostPosted: Sat Aug 26, 2006 3:27 am    Post subject: Infinities Reply with quote Reply with quote including images
I have just put some infinity reference 5.5" and the speaker fits straight in with the tweeter using the same mount as the existing and just bolting straight on.
Great sound - easy fit, deep tone.
Gavin
Back to top
jrleech
Premium Member
PostPosted: Sun Aug 27, 2006 7:36 am    Post subject: Reply with quote Reply with quote including images
5" Focal Poly Kevlar 130K.... straight swap. Tweeters needed casing cutting down to fit inside tweeter location.
I think all 5" speakers fit straight in without spacers??
Cheers,
Jon
Back to top
User is offline
nailmonkey
1995 Toyota MR2 MK2 BeamsVVTi
PostPosted: Sun Aug 27, 2006 9:25 am    Post subject: Reply with quote Reply with quote including images
Hi Neil.
I've got Focal Access 165 (6.5") which needed 18mm spacers. The tweeters fit straight into the stock location though.
Nik
Back to top
User is offline
Neil_turbo
PostPosted: Sun Aug 27, 2006 4:02 pm    Post subject: Reply with quote Reply with quote including images
Cheers Nik, Jon, Gav (Welcome to IMOC [Very Happy] )
List updated!
We are going to need more speakers if this list is going to become usefull!
Neil
Back to top
User is offline
sadgav
Guest
PostPosted: Mon Aug 28, 2006 9:20 pm    Post subject: speakers... Reply with quote Reply with quote including images
sorry, made a boob - mine are 6.5" in the front - but still went straight in with no mods whatsoever.
(nice to be welcomed!)
Gavin.
Back to top
mushky
Guest
PostPosted: Tue Aug 29, 2006 8:22 am    Post subject: Reply with quote Reply with quote including images
mk2. 6.5" DLS R6A comps in the front with a 15mm spacer. Tweeters went straight in.
sub in Neil's box is Infinity 10" 1040W
Back to top
Bonmaklad
Guest
PostPosted: Tue Aug 29, 2006 10:18 am    Post subject: Reply with quote Reply with quote including images
i got kicker 6.5INCH ni the front sound perfect!!!! and a nice jbl 10inch in the back of passesnger seat
Back to top
Sidewinder
PostPosted: Tue Aug 29, 2006 5:58 pm    Post subject: Reply with quote Reply with quote including images
Great idea Neil. Perhaps one of the Admin team could make this a sticky for this section?
Back to top
User is offline
SwitchBlade
PostPosted: Tue Aug 29, 2006 7:28 pm    Post subject: Reply with quote Reply with quote including images
MKII
Helix HXS235 - I believe 12mm baffle
Helix RS6.3 - mid needs a 36mm baffle, or with light surgery to the door you can get away with 18mm, no hope of tweet fitting in stock location mind. [Smile]
Image Dynamics CX62 - magnet just fits through door hole, again 36mm baffle to fit without surgery.
Back to top
User is offline
Neil_turbo
PostPosted: Fri Sep 01, 2006 5:34 pm    Post subject: Reply with quote Reply with quote including images
Any spacers required mate - tweeters fit ok?
Neil
Back to top
User is offline
Neil_turbo
PostPosted: Fri Sep 01, 2006 5:36 pm    Post subject: Reply with quote Reply with quote including images
SwitchBlade wrote:
MKII
You know what sizes these are off-hand, if not will find out on google [Smile]
Neil
Back to top
User is offline
Neil_turbo
PostPosted: Fri Sep 01, 2006 5:37 pm    Post subject: Reply with quote Reply with quote including images
Cheers Nige!
It should save a lot of questions in this part of the forum, will speak to a mod when its a bit more developed!
[Very Happy]
Back to top
User is offline
SwitchBlade
PostPosted: Fri Sep 01, 2006 5:39 pm    Post subject: Reply with quote Reply with quote including images
Sorry mate the 235s are 5.25" the others are 6.5".
Back to top
User is offline
Neil_turbo
PostPosted: Fri Sep 01, 2006 6:02 pm    Post subject: Reply with quote Reply with quote including images
Cheers mate, you know about the tweeters on the last set?
Nice Install btw!
Neil
[Very Happy]
Back to top
User is offline
SwitchBlade
PostPosted: Fri Sep 01, 2006 6:24 pm    Post subject: Reply with quote Reply with quote including images
The Image Dynamics are just mid-bass units. There are ID tweeters and horns to go with them but I've not owned either.
Back to top
User is offline
Neil_turbo
PostPosted: Sat Sep 02, 2006 7:47 am    Post subject: Reply with quote Reply with quote including images
cheers mate! Updated again!
Back to top
User is offline
Quigonjay
Premium Member
PostPosted: Sat Sep 02, 2006 10:58 am    Post subject: Reply with quote Reply with quote including images
great idea neil, can we have this as a sticky mods?
Back to top
User is offline
Neil_turbo
PostPosted: Sun Sep 24, 2006 7:26 pm    Post subject: Reply with quote Reply with quote including images
cheers mate!
were going to need more contributions if this is going to be any use as a sticky!
Come on people!
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> ICE and Security All times are GMT
Page 1 of 5
Jump to:
