funny box thing and huge cables under drivers seat????????
anyone know what this could be??? is it standard?????? i havent had a chance yet to get a torch under there to check, but any ideas????
Re: funny box thing and huge cables under drivers seat????????
Is it the electrical wiring for the seatbelt warning light on the dash??
didnt some of the cars have the amp for the stereo under the seat ?
I'm going with Rowland's answer being the one. The cable should be covered by plastic, and you should find a plug in the middle of it. If/when you take the seats out, you disconnect this plug.
Mk2 NA Rev1 -*- Mk2 Turbo Rev2 -*- Mk1 NA -*- Mk2 Turbo Rev 3 = all gone!
_______________________________________
"Cruisey, Sporty, more innovation, more adult. A Man In Dandism. Powered mid-ship specialty."
the only thing is tho, he said its a funny box thing with huge cables coming out from it, I wouldnt have thought that a sensor for the seat belt would have used such huge cables
Well...the plastic cable cover is quite thick (about 10mm) if I remember correctly, so that might be it. There's no actual sensor under the seat, just the plug thing. The light on the dashboard is made through a basic electrical connection using the metal of the seatbelt clip.
Will - are you the same Will with a red MR2 that turned up to the last Hobby Horse meet? If so...hello mate!
it could be something to do with your alarm if you have one fitted cuz when i got mine done he put something under my seat
Are you the same Nige that had a black MR2 Turbo? if so HI If not then........ Hi anyway
It's most likely the remote central locking control box. If you find you haven't got a key with buttons on then it's most likely not made it over from Japan. Look also for a button with a key symbol on it on the dashboard for confirmation.
I've seen lots of these and given the generally ad-hoc nature of their installation I would guess they're a dealer fit item.
Rogue
Rogue
Rogue wrote:It's most likely the remote central locking control box. If you find you haven't got a key with buttons on then it's most likely not made it over from Japan. Look also for a button with a key symbol on it on the dashboard for confirmation.
Rogue
yeah could be! my GTS has such a wire under the seat and remote locking and a switch with a key on the dash to turn it on and off which always confused me???
not really needed with my alarm key fob now but was a nice little extra to have before i had the alarm as i hate non-remote locking cars, finding key holes in the dark is how you get scratches
