[Mk2] [Turbo] Suspected cv joint failure
Author Message
chrisE
Premium Member
PostPosted: Tue Apr 16, 2019 6:58 pm    Post subject: [Mk2] [Turbo] Suspected cv joint failure Reply with quote Reply with quote including images
Hi everyone,
I think my left rear cv joint is quickly failing on my '95 turbo, started making a knock noise increasing in speed, now it's a grinding noise. I can't seem to find a blue print replacement, just "shaftec" ones, are these worth a punt? Or should I just get a used driveshaft complete with joints?
Thanks in advance
Back to top
User is offline
Juliuswws
PostPosted: Tue Apr 23, 2019 4:05 pm    Post subject: Re: [Mk2] [Turbo] Suspected cv joint failure Reply with quote Reply with quote including images
chrisE wrote:
Hi everyone,
Thanks in advance
Is it the inner or the outer CV?
Back to top
User is offline
chrisE
Premium Member
PostPosted: Tue Apr 23, 2019 4:44 pm    Post subject: Reply with quote Reply with quote including images
Neither. Turned out to be two loose nuts on the wheel. Panic over [Laughing]
Back to top
User is offline
Display posts from previous:
Page 1 of 1
Jump to:
