[Mk2] [Turbo] Link G3 base map
Looking for a base map for link g3 with 800cc injectors. I have the car running but it's rubbish when any amount of throttle is applied. Certainly not driveable. I want to load in a base map to see if it's any better (or worse). The map I'm using is off an identical build, Only deifference being the cams.
