[Mk2] [Turbo] Remove mbc to return to stock
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications
Author Message
oddshoes
Premium Member
2001 Toyota MR2 Mk3 MR-S
PostPosted: Sun Nov 04, 2018 3:07 pm    Post subject: [Mk2] [Turbo] Remove mbc to return to stock Reply with quote Reply with quote including images
Hi All
I recently bought a mk2 turbo (rev2 turbo) as a project been a while since I have had a turbo and been about 10 years since I have had a rev1, I want to return it it to stock it currently has a mbc and blitz bov!
Anyone got any bits or have a link to returning to stock please
Dave[/b]
Back to top
User is offline
Rory
1996 Toyota MR2 Mk2 Turbo Rev3
PostPosted: Mon Nov 05, 2018 1:16 pm    Post subject: Reply with quote Reply with quote including images
Hey. I think removing the mbc should be easy. Just find it and replace it with a straight piece of pipe. The stock recurculation valve may be harder to come by. I can understand removing the bov but why do you wish to remove the mbc and make it slower? How much boost is it currently running?
Back to top
User is offline
oddshoes
Premium Member
PostPosted: Mon Nov 05, 2018 9:03 pm    Post subject: Reply with quote Reply with quote including images
I bought it as a project as the head gasket has possible gone but I want to return it to a fairly stock motor as it's a rev2 turbo tin top in aircon, it also has cruise control too.
The mbc is venting to atmosphere as it has 3 ports. I want to see it stock to get it right and then take it from there
Back to top
User is offline
Rory
PostPosted: Mon Nov 05, 2018 9:21 pm    Post subject: Reply with quote Reply with quote including images
[url]https://youtu.be/79uKJqxTy8s[/url]
Check this video. I’m pretty sure you just need to remove the mbc and join the 2 pipes going into it. Or better still replace with a single pipe and don’t have a join.
Back to top
User is offline
jimGTS
1997 Toyota MR2 Mk2 Turbo Rev4
PostPosted: Tue Nov 06, 2018 12:33 pm    Post subject: Reply with quote Reply with quote including images
youll also need to reconnect the tvsv if its been blocked/plugged....(right hand actuator port)
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications All times are GMT
Page 1 of 1
Jump to:
