Hi,
Has anyone had any success in plastic welding broken fog light mounts together again?
I am thinking about trying it, as mine are steering fogs, but need to figure out what type of plastic etc is used and if it is worth doing.
thought maybe someone else has tried and has some useful info
Thanks,
Tony
[Mk2] [Turbo] Plastic welding broken fog mounts?
Re: [Mk2] [Turbo] Plastic welding broken fog mounts?
I have done loads of these. Soldering iron and black zip ties.
alanmr2turbo wrote:I have done loads of these. Soldering iron and black zip ties.
That will do nicely - thanks a mil
Tony
I've looked at plastic welding recently to fix my splitter, it seems heat and a polyethylene does the job easily. Hard part is trying to jack the front of the car up
platmatt8 wrote:I've looked at plastic welding recently to fix my splitter, it seems heat and a polyethylene does the job easily. Hard part is trying to jack the front of the car up
park the front on some planks of wood to give a little room for the jack?
I used Q-Bond to fix mine, seemed to work ok.. Then drilled out the stock captive nuts and put rivnuts in...
- wilkie senior
Perhaps not full of finesse
But i did this on my White Rev1 stayed put & still there when i sold them on
