Oil lines
almeida1234
Oil lines
Post by almeida1234 »
Hey guys
Are the oil line same on c26 and c20 turbo?
I am just swapping c26 with a c20. Wanted to make sure before I start tackling this job?
Many thanks
MartinF
Re: Oil lines
Post by MartinF »
I did this last year.
They will fit fine with a little bit of bending. However you may want to read my observations of the turbo support bracket:
Blue Lexus RCF
Black MKIV UK Manual Supra
Green MK2 MR2 Tin Top
rgb
Re: Oil lines
Post by rgb »
drill the hole in the bracket bigger and use a washer .ive got a 26 on a 20 bracket. I wouldn't leave the bracket off or the down pipe will crack
almeida1234
Re: Oil lines
Thansk boys
