Alternative part for tbar roof
Author Message
autobody
1988 Toyota MR2 Mk1 SC
PostPosted: Tue May 09, 2017 7:29 am    Post subject: Alternative part for tbar roof Reply with quote Reply with quote including images
Hi all, I've had a new windscreen fitted and the roof sprayed on my car. So all tbar trims were removed. I am going to be putting them back in but realised I need the 2 sticky felt type plates (not sure on proper name). See pic below with the parts highlighted.
Toyota don't stock the part anymore. I am assuming I would need to have a set.
Does anyone know of an alternative which I could buy and cut to required shape?
Here is the part number: 63234-17010
Here is a pic taken from jinxy page:
Back to top
User is offline
alanmr2turbo
PostPosted: Tue May 09, 2017 7:50 am    Post subject: Reply with quote Reply with quote including images
not sure if this is any good [Think]
http://www.ebay.co.uk/itm/Self-Adhesive-Felt-Baize-Fabric-Mini-Rolls-BLACK-/272375989485?var=&hash=item3f6adfc4ed:m:mqwVQqE0czOTrq3KbLoa1ew [Think]
Back to top
User is offline
autobody
PostPosted: Tue May 09, 2017 8:25 am    Post subject: Reply with quote Reply with quote including images
Thanks Alan. From your eBay result I found this one:
https://www.ebay.co.uk/itm/232286578341
Sounds stronger, but not sure if it will have a negative effect.
Back to top
User is offline
Display posts from previous:
Page 1 of 1
Jump to:
