4age to 4agze conversion
Goto page Previous  1, 2
Author Message
SuperRedMR2
1990 Toyota MR2 Mk1b
PostPosted: Fri Apr 28, 2017 10:20 pm    Post subject: Reply with quote Reply with quote including images
I don't know what the fascination is with the frunk.
With the battery, would I still be able to fit my full size spare wheel? I doubt it.
Back to top
User is offline
jimi
1988 Toyota MR2 Mk1b
PostPosted: Sun Apr 30, 2017 11:58 am    Post subject: Reply with quote Reply with quote including images
Lauren wrote:
I have to say that as an electrician that picture is somewhat scary [Shocked]
Back to top
User is offline
Lauren
PostPosted: Mon May 01, 2017 8:10 am    Post subject: Reply with quote Reply with quote including images
The bit of angle was aluminium.
_________________
2013 GT86 Injen Induction. Volks Racing TE37s & TRD Aero Fins, Mega sounds. TEIN Street Flex 5/6kg, TEIN EDFC Active Pro. Tuning Developments Remap 4-1 Manifold, TD resonated exhaust, decat/overpipe, AP Racing 4 Pot front brakes. [lover]
Back to top
User is offline
SuperRedMR2
PostPosted: Mon May 01, 2017 8:26 am    Post subject: Reply with quote Reply with quote including images
Lauren could you fit your spare wheel in the front with that setup?
I'd rather lose a section of my boot space than lose my spare wheel.
Back to top
User is offline
autobody
1988 Toyota MR2 Mk1 SC
PostPosted: Mon May 01, 2017 9:12 am    Post subject: Reply with quote Reply with quote including images
Paul Woods did the battery mod to perfection. I am sure the wheel fitted too but there was a lot more fabrication with what he did.
His battery was in the front but higher up and on the right.
My car had the battery at the front and the spare wheel fitted, but it was the space saver type that I had.
Back to top
User is offline
Angpozzuto
Premium Member
1989 Toyota MR2 Mk1b
PostPosted: Mon May 01, 2017 9:24 am    Post subject: Reply with quote Reply with quote including images
I've mounted my battery in the frunk of my car, I think I've gone a similar route to woodsport and mounted it on the passenger side and run the cable under the carpet along the sill and there's a few holes in the bodywork from the factory that can be made use of. I'll upload a pic of mine later
Back to top
User is offline
qwakers
PostPosted: Mon May 01, 2017 9:28 am    Post subject: Reply with quote Reply with quote including images
you are aware that aluminium conducts electricity too right?
Back to top
User is offline
Lauren
No, though I've never worried about carrying a spare wheel.
Back to top
User is offline
Lauren
PostPosted: Mon May 01, 2017 9:29 am    Post subject: Reply with quote Reply with quote including images
I never had a problem with it. The battery was very tightly clamped down.
Back to top
User is offline
jimi
PostPosted: Mon May 01, 2017 10:27 am    Post subject: Reply with quote Reply with quote including images
If you'd ever seen can happen when you short out a lead acid car battery you would never position a strip of metal (any metal, it all conducts) that close to the battery terminals.
It's not just a question of the battery moving, what about when your disconnecting/connecting the leads or removing the clamp ?? very easy to short out the battery.
Murphy's Law wrote:
Anything that can go wrong will go wrong
with the corollary that
Quote:
Anything that can't possibly go wrong ... will go wrong.
No point in taking a chance when you don't have to, IMHO
It could have been positioned an inch further forward away from the terminals and insulated along its length, I certainly would have and would recommend that anyone fitting a similar type clamp does the same.
Back to top
User is offline
SuperRedMR2
PostPosted: Mon May 01, 2017 2:14 pm    Post subject: Reply with quote Reply with quote including images
Mine will be going in the boot (rear). Cannot think about not having a spare but mine is full size.
I'll get a boot installation made up and secured safely in place.
Back to top
User is offline
Lauren
PostPosted: Mon May 01, 2017 2:50 pm    Post subject: Reply with quote Reply with quote including images
Fair comment. I did scrap the car about ten years ago though, so it's long gone!
Back to top
User is offline
SuperRedMR2
PostPosted: Fri May 05, 2017 3:40 pm    Post subject: Reply with quote Reply with quote including images
Picking the car up on Sunday [Dancing]
Back to top
User is offline
oukie
IMOC Organiser
1987 Toyota MR2 Mk1b
PostPosted: Fri May 19, 2017 11:44 am    Post subject: Reply with quote Reply with quote including images
Update?
_________________
Mk1b White T-bar SC 1987, Mk1b White coupe Jan90, Mk1b White coupe Jan90 (spares), Mk1b Mica blue T-bar Mar90, Mk1b Mica blue T-bar,full climate control,Jan90, 5 mk1's [Smile]
Back to top
User is offline
SuperRedMR2
PostPosted: Sat May 20, 2017 11:03 am    Post subject: Reply with quote Reply with quote including images
Sorry, I picked it up and went for a blast down the A133 before the A12 and the intercooler pipe blew off which made an incredible sound! Not!
Burnt my hands putting it back on, but since then fixed the hose properly and my god it's a weapon!
Running without an air filter at the moment due to not having correct diameter rubber hoses but that'll be sorted in a few weeks. The intercooler brackets are going to be remade for something stronger, but all in all it's been very good so far.
I need a Toyota oil filter as the halfords one I HAD to buy at the time, doesn't allow the oil to stay in the filter so it drips back to the sump.
It's got the big pulley, the camry idlers, 4-2 exhaust manifold, ABV mod but the SC belt is squeaking at the moment so need to tighten that up.
Will get it on a dyno soon but i need to replace my 14 yr old tyres and all of the suspension, but will be ordering BC coilovers soon.
Back to top
User is offline
Lauren
PostPosted: Sat May 20, 2017 5:33 pm    Post subject: Reply with quote Reply with quote including images
Sounds good. Blank off the ABV though. We did tests on the 'ABV mod' years ago and it will cost you boost pressure. It's a bit a bodge really.
An oil filter is very easy to get off the shelf at Toyota as they use the same filters for lots of their cars.
Back to top
User is offline
SuperRedMR2
PostPosted: Sat May 20, 2017 10:44 pm    Post subject: Reply with quote Reply with quote including images
sorry the ABV is blanked off
Back to top
User is offline
Lauren
PostPosted: Sun May 21, 2017 8:39 am    Post subject: Reply with quote Reply with quote including images
[thumbsup]
Back to top
User is offline
SuperRedMR2
PostPosted: Sun May 28, 2017 9:58 am    Post subject: Reply with quote Reply with quote including images
I'm still running with no air filter but I've ordered a 70mm 45 elbow to remedy this problem.
Is there a way of turning the boost up on a hidden screw somewhere? I'm sure somewhere I've seen it mentioned...
Back to top
User is offline
Lauren
PostPosted: Sun May 28, 2017 12:16 pm    Post subject: Reply with quote Reply with quote including images
No. The boost is simply limited by crank speed and size of your crank and supercharger pulley. The trouble is with boost pressure (if you have a gauge) is that it is depedent upon the efficiency of your intercooling. As the intake temps get higher the air expands becoming less dense but giving more boost pressure and less power of course.
Back to top
User is offline
Display posts from previous:
Page 2 of 2
Jump to:
