parts left from breaking rev 3 turbo
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2s Being Broken
Author Message
Jamitsi
PostPosted: Tue Oct 18, 2016 10:55 am    Post subject: parts left from breaking rev 3 turbo Reply with quote Reply with quote including images
i still have some parts left from breaking my rev 3 turbo
the car will be going soon, so if any parts anyone needs, this could be last chance
Air con Matrix 10
Air con long pipes( front to back) 10
Heater Matrix 10
Heater blower/fan unit 10
fuel tank 10
space saver wheel/unused 10
heater pipes (front to back) 10
Coolant pipes (front to back) 10
wiper motor and linkage 10
ABS unit 10
battery to starter cable 5
front loom and fuse box (frunk) 10
Accelerator pedal and cable 5
washer bottle and pump 5
Frunk pull catch and cable 5
passenger side headlight cover 5
coolant radiator and fans 10
cover in frunk (small split) 5
indicator/light/wiper stalks 5
boot carpet 10
boot boards 5
a lot of interior parts, carpets, centre dash(vents), visors, glove box, centre cubbies, a, pillars( divers broken at the lower part of the door, tin top), cubby behind seats, sill covers,
probably a quite a few parts i have missed, also lots of nuts and bolts
also apexi turbo timer with sw20 loom,40
all prices plus delivery and paypal charges, obviously some parts will be collection only.
any questions just ask.
jamie
Back to top
User is offline
mr2nut123
Premium Member
PostPosted: Tue Oct 18, 2016 4:12 pm    Post subject: Reply with quote Reply with quote including images
Your centre vents in perfect order mate? Mine have clearly has cup holders on them and some numpty has torn them off and snapped the middle fins.
Can I exchange my loyalty points? [Laughing]
Back to top
User is offline
qwakers
PostPosted: Tue Oct 18, 2016 4:26 pm    Post subject: Reply with quote Reply with quote including images
have you got the heater control cable?
Back to top
User is offline
monkeyra
Premium Member
1990 Toyota MR2 Mk2 V6
PostPosted: Tue Oct 18, 2016 5:20 pm    Post subject: Reply with quote Reply with quote including images
I'd be interested in:
And do you have the following?
1) Tintop headlining
2) The coat hooks which go beneath the rear window
3) The piece of black dashboard trim that incorporates the ignition switch
4) Drivers footrest (in the footwell) - I need the clips as I bust mine removing it the other week [Sad]
_________________
SW20 Rev1 Supercharged 2GR-FE Powered Trackday Car.
Back to top
User is offline
Jamitsi
PostPosted: Tue Oct 18, 2016 8:27 pm    Post subject: Reply with quote Reply with quote including images
Pms sent to all
Back to top
User is offline
Jerry
PostPosted: Wed Oct 19, 2016 10:49 am    Post subject: Reply with quote Reply with quote including images
Do you have All air con related to make non AC car -> AC ?
Back to top
User is offline
Jamitsi
PostPosted: Wed Oct 19, 2016 9:01 pm    Post subject: Reply with quote Reply with quote including images
Hi
I only have the front to rear pipes. And the matrix
Other parts have been sold.
Jamie
Back to top
User is offline
qwakers
PostPosted: Sat Mar 04, 2017 1:15 pm    Post subject: Reply with quote Reply with quote including images
have you still got the boot carpet and the little cubby below the radio
many thanks.
Back to top
User is offline
rainen
Premium Member
1998 Toyota MR2
PostPosted: Wed Mar 22, 2017 6:44 pm    Post subject: Radiator Reply with quote Reply with quote including images
Have you still got the car? I'm just looking for the rad fan temp sensor out of the radiator if you can get it out (19mm long socket)? Thanks.
Back to top
User is offline
tottacrolla
PostPosted: Sun May 07, 2017 5:55 pm    Post subject: Reply with quote Reply with quote including images
Air con matrix still for sale ?
Back to top
User is offline
tehdub
Premium Member
1990 Toyota MR2
PostPosted: Thu Jun 01, 2017 4:36 pm    Post subject: Reply with quote Reply with quote including images
Hi Jamie,
Does the Frunk loom have the connectors for the speedo/gauge cluster?
I don't need the whole loom, just the connectors with about 6 inches of wire hanging off, but happy to have the whole thing if it is easier.
Cheers,
Tom
Back to top
User is offline
Gazza_DJ
Premium Member
1997 Toyota MR2 Mk2 NA Rev4
PostPosted: Wed Jul 26, 2017 1:42 pm    Post subject: Reply with quote Reply with quote including images
Do you have ABS hubs, if so is the passenger rear hub available / is it in decent condition / complete with sensor?
Back to top
User is offline
Skinner248
PostPosted: Wed Aug 02, 2017 12:17 pm    Post subject: Reply with quote Reply with quote including images
Driveshafts?
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2s Being Broken All times are GMT
Page 1 of 1
Jump to:
