[Mk2] [NA] 1999 MR2 Mk2 SW20 Aerial PDF
Heliwilly
Post by Heliwilly »
I was looking at the pdf a while ago on the Knowledge Base and tried to go onto the site yesterday, but got an HTTP 404 error?? Unable to access the .pdf document.
Bill W
Nic
Re: [Mk2] [NA] 1999 MR2 Mk2 SW20 Aerial PDF
Post by Nic »
Nic
[email protected]
MR2 Rev 3 GT Turbo
Heliwilly
Post by Heliwilly »
That's the one Nic, many thanks for your help. Bill W.
Heliwilly
Post by Heliwilly »
Just fitted an aerial to my MR2, that I bought form Jamitsi a member on this site. I have now found out that there are at least 3 versions of the wiring of these aerials to the aerial relay box attached to the aerial. In the knowledge base, there are 8 connections numbered 1 to 9, with No7 not used, 8 wires connected. On the 1994 one I bought from Jamitsi, the connections are, 1 to 8 with all 8 pins used. On the 1999 one I took off the pins are numbered 1 to 8 and only 7 used. The Red with a White stripe isn't there as it was with the 1994 aerial. As I knew that the motor on mine worked, I just swapped the wiring harness with the 3 connectors from my old 1999 aerial to the 1994 one fitted the aerial and it worked fine.
Happy but confused!!!
In the cct diagram in the knowledge base the Red/White pin 8 connection is used as a +ve to raise the aerial and it stays raised until this pin goes to 0v.
If anyone knows why I would be interested Thanks Bill W.
Return to “Electrical”
