[Mk2] [Generic] OEM headunit brackets - dont fit single DIN media (CD less) unit
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> ICE and Security
Author Message
raptor95GTS
PostPosted: Tue Jun 09, 2015 12:47 pm    Post subject: [Mk2] [Generic] OEM headunit brackets - dont fit single DIN media (CD less) unit Reply with quote Reply with quote including images
ok, I'm obviously being stupid here but how the dickens does the OEM Double DIN brackets fit single DIN stereos? Bought a unit, didn't fit so sent it back. Went to Halfords with the brackets and got them to open up a box of the headunit I wanted. The brackets just don't fit, either the screw holes don't line up or the locating pins on the brackets foul the head unit. I know I'm missing something here but I just cannot figure it out. [Crying or Very sad]
Back to top
User is offline
acf8181
Premium Member
1994 Toyota MR2 Mk2 NA Rev3
PostPosted: Tue Jun 09, 2015 3:01 pm    Post subject: Reply with quote Reply with quote including images
Screws always lined up for me....most aftermarket units do stick about 5mm out of dash so screw holes are further back on the unit than you may expect.
Back to top
User is offline
raptor95GTS
PostPosted: Tue Jun 09, 2015 3:38 pm    Post subject: Reply with quote Reply with quote including images
I've managed to find all the mounting hardware so tomorrow back to Halfords and get it sorted. Cheers [thumleft]
Back to top
User is offline
raptor95GTS
PostPosted: Wed Jun 10, 2015 9:27 am    Post subject: Reply with quote Reply with quote including images
ok, found out what the problem is. The newer media units, ie no CD player are half the depth of the CD units and have different mounting options / bolt hole arrangements meaning the OEM brackets don't fit! So much for standardisation...........
Back to top
User is offline
Gazza_DJ
Premium Member
1997 Toyota MR2 Mk2 NA Rev4
PostPosted: Mon Jun 29, 2015 10:51 am    Post subject: Reply with quote Reply with quote including images
My mechless unit (Alpine iDA-X100) fitted the stock brackets fine, as does my mechless double DIN pioneer unit. You should be able to find a unit that will work fine with those, I would think the ones that don't are in the minority.
Back to top
User is offline
acf8181
Premium Member
PostPosted: Tue Jun 30, 2015 12:11 pm    Post subject: Reply with quote Reply with quote including images
i have a half depth unit in my mr2...just only used 2 of the 4 screws
Back to top
User is offline
raptor95GTS
PostPosted: Thu Jul 02, 2015 9:26 pm    Post subject: Reply with quote Reply with quote including images
okdokey, I shall head back out to the shops and see what I can get [thumleft]
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> ICE and Security All times are GMT
Page 1 of 1
Jump to:
