[Mk2] [Turbo] Connecting boost controller
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications
Author Message
killerferret666
PostPosted: Fri Oct 17, 2014 8:34 pm    Post subject: [Mk2] [Turbo] Connecting boost controller Reply with quote Reply with quote including images
Just wondering where can I pipe in a boost controller pipe;
With so many hoses removed on my build it seems silly to T for no reason. Can I attach it to one of the 2 outlets on the top of the throttle body, which normally get looped or blocked off?
Back to top
User is offline
raptor95GTS
Premium Member
PostPosted: Sat Oct 18, 2014 11:56 pm    Post subject: Reply with quote Reply with quote including images
yes you can, just confirm you see pressures both above and below 0psi Gauge at the one you chose [thumleft]
Back to top
User is offline
madmr2man
Premium Member
PostPosted: Sun Oct 19, 2014 6:24 am    Post subject: Reply with quote Reply with quote including images
Yes, that location will be fine
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications All times are GMT
Page 1 of 1
Jump to:
