[Mk2] [Turbo] Replace Aerial Stalk = Stereo Dead
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Electrical
Author Message
Mike
PostPosted: Sun Dec 15, 2013 5:42 pm    Post subject: [Mk2] [Turbo] Replace Aerial Stalk = Stereo Dead Reply with quote Reply with quote including images
So I finally got around to replacing my aerial stalk, and now I have no power to the stereo. The dome fuse looks fine as does the radio fuse (top left 15a fuse in the footwell I believe?)
Checked behind the stereo and all looks ok, any ideas?
Back to top
User is offline
Dame
Premium Member
PostPosted: Sat Feb 22, 2014 8:40 pm    Post subject: Reply with quote Reply with quote including images
Have you tried disconnecting the arial to see if the stereo starts working. TBH I would doubt it will make a difference since any short would blow fuses but maybe worth a try...
Back to top
User is offline
keiith9849
PostPosted: Fri Jun 23, 2017 8:23 pm    Post subject: Reply with quote Reply with quote including images
You have probably lost the earth somewhere in the aerial-fixing process. Run new earth, ad things will probably light up (in a good way)!
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Electrical All times are GMT
Page 1 of 1
Jump to:
