6 speed LSD Mk1 gearbox build
Author Message
[email protected]
IMOC Affiliated Company
PostPosted: Mon Jan 14, 2013 7:41 am    Post subject: Reply with quote Reply with quote including images
Interestingly the new 4.312 FD ratio for the 6 speed takes the theoretical top end speed up to 144mph v 128mph on the 5 speed, assuming the 4a-ge has the power to get it there.
_________________
Back to top
User is offline
gon
PostPosted: Mon Jan 14, 2013 7:41 pm    Post subject: Reply with quote Reply with quote including images
no prob, thank you Paul for all your contribution, including this thread.
I have pictures of the crown and pinion of the c52 and of the c64 (celica T sport) if anybody fancies counting teeth I can put them up.
The C64 (celica and corolla T sport) does have a 4.53 final ratio
I am attempting to put the gear ratios of the C64 inside a C52, and keeping the mk1b driveshafts, for that I am trying to swap the spider gears inside the open diff... let us see how that goes ....
Back to top
User is offline
[email protected]
PostPosted: Mon Jan 14, 2013 7:59 pm    Post subject: Reply with quote Reply with quote including images
Interesting idea swapping the spiders, wouldn't it just be easier for you to run a pair of Mk2 shafts though?
That really is job done and they are stronger than Mk1 shafts.
Back to top
User is offline
gon
PostPosted: Mon Jan 14, 2013 8:06 pm    Post subject: Reply with quote Reply with quote including images
It would be, but budget is reallyyyy tight now...
I will see if I can get the clearances right, if not I will have to spend another 100 quid on them shafts ... but then if I already have the shaft I would probably get the mk3 lsd .... and the missus will not be happy at all [Mr. Green]
Back to top
User is offline
[email protected]
PostPosted: Tue Jan 15, 2013 7:42 am    Post subject: Reply with quote Reply with quote including images
Who is in charge of the Mk1 knowledge base these days?
Back to top
User is offline
Peter Gidden
2002 Noble M500
PostPosted: Tue Jan 15, 2013 8:45 am    Post subject: Reply with quote Reply with quote including images
[email protected] wrote:
Who is in charge
wassat?
[Mr. Green]
Back to top
User is offline
The Silver Fox
Premium Member
1985 Toyota MR2 Mk1a
PostPosted: Tue Jan 15, 2013 1:19 pm    Post subject: Reply with quote Reply with quote including images
Paul,
I have no technical knowledge of gearboxes but given that your long fifth gear mod also has a ratio of 0.725, what are the differences in performance between the boxes? Am I correct in assuming the six speed box will give better acceleration?
Back to top
User is offline
jimi
1988 Toyota MR2 Mk1b
PostPosted: Tue Jan 15, 2013 3:20 pm    Post subject: Reply with quote Reply with quote including images
Excellent write up Paul [thumleft] Do you mind if I copy it it for KY2 ? Credited to you of course [Smile]
Back to top
User is offline
stenky
1989 Toyota MR2 Mk1b
PostPosted: Tue Jan 15, 2013 3:26 pm    Post subject: Reply with quote Reply with quote including images
The Silver Fox wrote:
Paul,
The contribution of this gearbox is twofold. Gears 2,3,4,5 provide better performance due to slightly shorter gearing. Namely its +7,7%(2nd) +13,1%(3rd) +20,3%(4th) and +12,4%(5th) torque to wheels increase over C52.
6th retains highway cruising efficiency as the fifth 0.725x4.312 mod.
Basically a win-win situation. Performance without compromising fuel consumption (not that I cared about this much).
Back to top
User is offline
[email protected]
PostPosted: Tue Jan 15, 2013 4:55 pm    Post subject: Reply with quote Reply with quote including images
Yes by all means Jimi fire away mate, i'm trying to get it added to the Imoc KB but not much response yet..... Imoc seems to be a ghost ship with nobody at the helm these days! [Very Happy]
Thankyou for clarifying Stenky.
Back to top
User is offline
jimi
PostPosted: Tue Jan 15, 2013 6:11 pm    Post subject: Reply with quote Reply with quote including images
Cheers Paul, it's done http://www.mr2oc.co.uk/know-your-2-knowledge-base/mr2-mk1.html?catid=3&prodid=2&kbartid=272 [Cool]
Back to top
User is offline
stenky
PostPosted: Tue Jan 15, 2013 6:24 pm    Post subject: Reply with quote Reply with quote including images
yay, my gearbox is going to be famous [Very Happy]
Back to top
User is offline
coanda
1988 Toyota MR2 Mk1 SC
PostPosted: Tue Jan 15, 2013 10:27 pm    Post subject: Reply with quote Reply with quote including images
Thanks for taking the time to share this with us Paul - will come in handy in the future considering how far away I am from Woodsport.
Any problems with the 4agze?
Back to top
User is offline
[email protected]
PostPosted: Wed Jan 16, 2013 6:59 am    Post subject: Reply with quote Reply with quote including images
I've been asked that a few times, in terms of fitting the gearbox to the engine it will fit, the SC shafts won't work though, they would need to be Mk1 for non LSD or Mk2NA for LSD.
What isn't clear is wether a SC has the same gearbox mounting position, i always presumed they were the same but when i came to put a SC engine into a Mk1 NA one time i had to modify the mounts.... so i'll have to say yes it will fit but might need torque mount mods.
Back to top
User is offline
MartG
PostPosted: Wed Jan 16, 2013 12:45 pm    Post subject: Reply with quote Reply with quote including images
IIRC The rear torque mount on an SC has, in addition to the two bolts that go vertically up from below, two bolts that go horizontally through the crossmember [Think]
Back to top
User is offline
[email protected]
PostPosted: Wed Jan 16, 2013 4:30 pm    Post subject: Reply with quote Reply with quote including images
Thanks Mart, i knew about the extra bolts, but i also think the torque mount relative position to the gearbox is also different, i think it's because the SC box is E series based and Mk1 NA box is C series.
Back to top
User is offline
[email protected]
PostPosted: Sun Jan 20, 2013 6:58 pm    Post subject: Reply with quote Reply with quote including images
Back to my question earlier last week, who is in charge or has access to the Mk1 Knowledge base? I think this article has enough merit to be added instead of it disappearing off list into the archives.
Back to top
User is offline
stenky
PostPosted: Sun Jan 20, 2013 8:18 pm    Post subject: Reply with quote Reply with quote including images
Looks like censorship>>expanding KB
I am sooo getting punished for this, but phuket [blackeye]
Back to top
User is offline
elbon50
PostPosted: Sun Jan 20, 2013 8:30 pm    Post subject: Reply with quote Reply with quote including images
I would suggest PMing Lauren or Chris (Limey) about that Paul
Back to top
User is offline
cartledge_uk
1986 Toyota MR2 Mk1 SC
PostPosted: Mon Jan 21, 2013 9:04 pm    Post subject: Reply with quote Reply with quote including images
You can add it yourself paul
see this thread
http://www.imoc.co.uk/forums/viewtopic.php?t=76755
Or I can for you if you want [thumleft]
Back to top
User is offline
Display posts from previous:
Page 2 of 6
Jump to:
