Hi all,
Wonder if you could help, I bought a fensport pullykit of ebay with no belt, wondered is there a replacement belt as fensport seem to be very expensive for belt, also is there a link for to show you how to fit pully?
Stew
fensport pully
- Lauren
- IMOC Committee
Re: fensport pully
You just need to get the right length belt, which can be done so from halfords IIRC (It's been a few years).
2020 GR Yaris - Circuit Pack
Re: fensport pully
Belt length depend whether or not you still have the aircon pump fitted. IIRC without aircon the belt is a 5PK975 ( ie 5PK followed by the belt length in mm )
Re: fensport pully
Hi stew, i strongly advise using the camry v6 idler pulley instead of the Ford one that's made of cheese with this kit, part number is 13503-62030
FENSPORT PULLY
Thanks for your replies all, can you tell me is the camry part number you quoted a Toyota order number ??? Is there a website to show you how to do the ABV valve bypass
Stew
Stew
Re: fensport pully
Yes, that's a Toyota part number.
Re: FENSPORT PULLY
stew wrote: Is there a website to show you how to do the ABV valve bypass
Best option is to put a metal blanking plate between the ABV and its mount - but of course that does require you to remove the ABV, make a blank, then refit the ABV.
The alternative ' ABV mod ' is detailed here http://www.ae86drivingclub.com.au/forum ... r-dummies=
Re: fensport pully
thanks for the help hope to get at it soon have had the pulley for a while but never got round to fitting
