Travelled to Nathan's 'Century Motorsport' today to have my new modified gearbox fitted.
We had spoken at length about my annoying 'rattle' upon start up and i ordered a new friction plate in advance in case it was that.
Old box came out with no real fuss, and the starter motor which was also suspected turned out ok. Next we looked at the clutch and flywheel...and there was the problem. The outer ring gear on the flywheel had worn and was loose, rattling around the casing of the flywheel. Some of the allen bolts were loose and the internal teeth had sheared.
My clutch had also worn down to the rivets!
So, a phone to Fensport and £700 later, a new flywheel & 6 puck clutch is being delivered to Nathan tomorrow.
Then he went the extra mile and offered me his own car for me travel home in! I now have a very nice white Nissan Skyline sitting on my drive! Really cant thank Nathan enough for this, talk about exceptional customer service!
Will be travelling back to Kidderminster from Kent either Thursday or Friday to swop the cars over, with a new gear box with final drive mod, a brand new clutch and spanking new Fidanza flywheel.
Just in time for Japfest.
[Mk2] [Turbo] Update on the transmission rattle! Problem solved!
- Scott Barton
- IMOC Committee
Re: [Mk2] [Turbo] Update on the transmission rattle! Problem solved!
Good stuff!
Have you gone with a brand new box or refurbed?
If new, how much did MRT remove from your wallet?
TOTB 2010 Rwd top speed, 1/4 and shootout winner.
10.7@142 on R888 street tyres, 10.3@134mph on slicks,
9's on slicks to come, with a clean full throttle pass! Goal of 0-150mph in a 1/4 of a mile....
what clutch have you gone for? hopfully not a fidanza stage 2 i have just sent mine back as it was faulty
- Scott Barton
- IMOC Committee
greeny wrote:Good stuff!
It was a refurbed box, but inspected throughout and the final drive mod from the GT4 installed. Nathan is taking it on a road test tomorrow.
As for the clutch, i did have a Helix 4 puck, but have upgraded to a Helix 6 puck.
The last one lasted around 7 years, Fensport had it on record me buying it in 2003! Considering i have been running in excess of 350bhp for 3 of those years, done a couple of track days, a TOTB day and some Santa Pod runs i am very impressed.
7 years thats some going
Re: diffy
Mike N wrote:Whats the gear ratio difference on the diff?
I take it the GT4 Diff gives quicker excelleration?
Its actually taller.
From 4.28 std to 3.9.
- Scott Barton
- IMOC Committee
Pics of the shot flywheel
Loose ring gear. Allen bolts have been drilled out here so we could remove it totally and inspect.
Stripped out internal teeth. These stop the ring gear from moving once pressed onto the flywheel and then secured with allen bolts.
This also explains the reason why once the flywheel was hot it stopped rattling. The aluminium expanded and 'locked' the ring gear down.
- IMOC Organiser
god i hope mine isnt this, ive a rattling when the clutch is depressed hoping its just release baring
- Scott Barton
- IMOC Committee
loudandproud205 wrote:god i hope mine isnt this, ive a rattling when the clutch is depressed hoping its just release baring
Does it stop when the engine has warmed up?
Get pics of the Skyline up White Skylines look amazing
- IMOC Organiser
dont think so and its only at slow speed i notice it thou but thats proberly due to the noise of the exhaust
Steve-O 2007 wrote:Get pics of the Skyline up White Skylines look amazing
It's not often you get a courtesy car that nice!
