Driveshaft oil seal part number required
CJ B
Post by CJ B »
Hi, I have a leaky o/s driveshaft seal (rev1 turbo) and need to know if the standard UK n/a part will fit. If not then if anyone has the part number or better still knows where I can get one from then I would be very grateful.
Cheers,
Chris.
^Trickster^
Re: Driveshaft oil seal part number required
Post by ^Trickster^ »
The NA one will not fit, they are too small.
There are 2 different sizes for the turbo aswell, eg each side is different, dont let them tell you both sides are the same side like the NA, I had alot of trouble getting hold of mine, luckily I got on with the guy at the parts desk and he ordered them all for me and I gave back the ones that didnt fit
Graeme
CJ B
Post by CJ B »
Its the O/S one that I want, the larger diameter.
gmtc
Post by gmtc »
Just replaced both driveshaft oil seals on my Rev1 Turbo yesterday!
the Totyota number for the seal on the offside (rear passenger side wheel) is 90311-50027. Cost around £15
CJ B
Post by CJ B »
gmtc wrote:Just replaced both driveshaft oil seals on my Rev1 Turbo yesterday!
Hi do you have the part number for the 'other' offside (driver) seal?
Cheers,
Chris.
gmtc
Post by gmtc »
Yes, will check tonight when i get home.
gmtc
Post by gmtc »
The other oil driveshaft oil seal is 90311-40004
When you remove the old ones, place them over the new ones for protection when tapping them home with a mallet.
CJ B
Post by CJ B »
Ta :)
