mr2 Turbo Basic performance upgrades
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.       www.imoc.co.uk Forum Index -> The Dungeon -> 3S Service Centre
Author Message
3S Service Centre
PostPosted: Sun Dec 06, 2009 2:20 pm    Post subject: mr2 Turbo Basic performance upgrades Reply with quote Reply with quote including images
ToyotaGT suggets the following checks are done before installation of any upgrades to assess the health of the engine.
-Leak down test
-Oil level/quality check
-Coolant level/strength test
-Timing check
The following items will be put under additional stress and may need changing if issues occur.
Ignition leads.
Distributor cap and rotor arm.
Coil.
Fuel Filter
Fuel pump
Clutch
Its the customers repsonsibility to ensure your braking system is
operating correctly/efficiently, if you are unsure you should ask for
assistance..
The power increase can be variable for various reasons if you tell us
what revision vehicle you have we can advise what is normal and how you
can ensure you get the best from the upgrades.
Stage 1 BPU
Manual boost controller
Fuel cut defender rev1/2
Cold grade Spark plugs
Boost Gauge installed
Total £250
Stage 2 BPU
Downpipe installed
TGT Cold air intake system
Total £650
Stage 3 BPU
Downpipe installed
TGT Electronic Boost controller installed
Total £820
Stage 4 BPU
Downpipe installed
TGT Uprated intercooler fitted
Total £1100
Stage 5 BPU
Downpipe installed
TGT customer chargecooler installed
Total £1570
Stage 6 BPU
Downpipe installed
TGT custom chargecooler installed
Hybrid turbo installed
Total £2320
Stage 6 BPU
Downpipe installed
Exhaust system
Total £2530
Bolts ons
Engine health checks £60
Apexi Power fc ecu fitted and mapped. £850
TGT Cold air intake system Fitted £150
Downpipe installed. £250
Boost Gauge installed. £90
TGT side mount intercooler fitted £280
TGT custom chargecooler installed. £900
Engine bay dress. from £100
Iginition leads. £85
Distributor cap and rotor arm. £45
Coil fitted £45
rev3 ecu conversion £550
Fuel Filter fitted £20
Fuel pump fitted £200
Clutch fitted From £300
Cambelt change From £180
Rebuilt forged engine installed From £3000
Various gauge installs From £90
TGT polshed manifold heatsheild fitted £50
Tyres £on request
Brakes Packages £on request
Suspension packages £on request
360 plus bhp tune £on request
400 plus bhp tune £on request
500 plus bhp tune £on request
Many more please ask
Back to top
User is offline
Display posts from previous:
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.       www.imoc.co.uk Forum Index -> The Dungeon -> 3S Service Centre All times are GMT
Page 1 of 1
Jump to:
