Bosch 044 Fuel Pumps
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> The Dungeon -> Deleted Momentum
Author Message
Momentum
PostPosted: Wed Oct 29, 2008 11:12 am    Post subject: Bosch 044 Fuel Pumps Reply with quote Reply with quote including images
Hi Guys..
We have a few of these in stock and are expecting more to arrive with us soon..
Bosch 044 Fuel pump..
Part# 0 580 254 044
Bosch 0 580 254 044 Inline Fuel Pump
Bosch 044 fuel pumps mount inline (out side of your petrol tank), most commonly rear center under your car. Each Bosch 044 inline fuel pump provides 300LPH of flow and operate at 72.5 PSI. Bosch 044 fuel pumps are comparable to the Walbro 255LPH high pressure inline fuel pumps which can both support vehicles for up to 600-700 horse power. Can be used in sequence with an intank Walbro or Bosch 040 fuel pump.
Bosch 044 Fuel Pump Specs:
Bosch Part Number: 0 580 254 044
Minimum Current: 12 Volts
Operating Pressure: 72.5 PSI (5 Bar)
Minimum Flow @ Outlet: 80 GPH (300 LPH)
Fuel Pump Location: In-Line
High Temperature Reduction: 8 GPH (30 LPH)
Weight: 1030 Grams (2.27 Pounds)
130 inc vat.
Contact Steven for more info.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> The Dungeon -> Deleted Momentum All times are GMT
Page 1 of 1
Jump to:
