Moroso 6.5 sump pans
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> The Dungeon -> Deleted Momentum
Author Message
Momentum
PostPosted: Fri Aug 22, 2008 11:22 am    Post subject: Moroso 6.5 sump pans Reply with quote Reply with quote including images
Hi Folks.. i have been offered these awesome moroso sump pans which will fit all mr2 turbo models 1990-1993 REV 1&2 ONLY
Exellent bit of kit, holds 6.15 litres of oil !!
I need to order at least 4 or 5 to keep the price reasonable on them..
The price is looking like its going to be about ?270-?275 inc VAT then + shipping from N.Ireland to wherever in the uk... i would say this will be approx ?15
just a little bit about these sump pans
Kicked-out sumps on each side of the pan increases capacity to 6.5 quarts without restricting ground clearance and helping to lower the average oil temperature
Solid windage tray with oil drain & dipstick cut out holes prevents oil from splashing back to the rotating assembly, robbing vital horse power
Trap door baffling allows oil to flow ?one way? into the pick-up area during hard acceleration and deceleration, preventing the pick-up screen from starving for oil
Rigid one piece 1/4" thick billet aluminum pan rail
Front of pan includes a 28mm threaded bung to accommodate the factory turbo drain back connection
Side of pan retains a 3/8" thick billet receptacle to accommodate the factory oil level sensor
Includes mounting kit with hex drive steel studs and serrated faced flanged nuts
Back to top
User is offline
Leakie Tbar
PostPosted: Fri Aug 22, 2008 11:29 am    Post subject: Reply with quote Reply with quote including images
What size is the return into the sump ??
Does it come with a adapter ??
Back to top
User is offline
Momentum
PostPosted: Fri Aug 22, 2008 1:51 pm    Post subject: Reply with quote Reply with quote including images
I have just edited the post and added a little discription of the sump pan
Trying to get some more solid info .
Hope this helps
Back to top
User is offline
greeny
1989 Toyota MR2 Mk2 Turbo Rev1
PostPosted: Thu Oct 16, 2008 2:06 pm    Post subject: Reply with quote Reply with quote including images
It uses the stock fitting
Back to top
User is offline
toxo
2010 Jaguar XF-R
PostPosted: Thu Oct 16, 2008 2:57 pm    Post subject: Re: Moroso 6.5 sump pans Reply with quote Reply with quote including images
Momentum wrote:
will fit all mr2 turbo models 1990-1995
I'm not sure that's entirely accurate, those dates are correct for USDM I think, so it will fit Rev1 and Rev2. Is that correct?
Back to top
User is offline
Ed
Premium Member
PostPosted: Thu Oct 16, 2008 3:00 pm    Post subject: Reply with quote Reply with quote including images
Correct, Moroso pans only fit upto Rev2 they do not fit the Rev3 onwards.
_________________
Understeer is when you hit the wall with the front of your car and oversteer is when you hit the wall with the rear of your car.
Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
Back to top
User is offline
Momentum
PostPosted: Thu Oct 16, 2008 3:17 pm    Post subject: Reply with quote Reply with quote including images
Indeed Folks...sorry about that.. i found this out a while ago but thought i had edited it... [d'oh!] silly me.
Moroso list that it fits a 90-95.. this is not entirely untrue as revision 2 models were available in the USA up till 1995.
But for us in the UK it will only fit rev 1&2 models.
Back to top
User is offline
Momentum
PostPosted: Wed Oct 22, 2008 10:22 am    Post subject: Reply with quote Reply with quote including images
Ok folks.. have some proper pics i took the other day of the real thing...
This really is a awesome bit of kit in the flesh...
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> The Dungeon -> Deleted Momentum All times are GMT
Page 1 of 1
Jump to:
