I must admit i never noticed the front lip
???, but being a late mk1 owner i guess i can be excused
Kevin on the other hand.
!!, the rear bumper appears to be original and is colour coded and the side skirts seem to belong to the car from new as all the bolt holes line up and seem to be factory fitted, this must be a late early spec if this makes sense
![Very Happy :D](./images/smilies/icon_biggrin.gif)
, air filter in the engine bay, early interior, since we have had it its had, replacement engine bay wiring harness, ECU, the smoothest gear box ive ever felt has been fitted, various replacement relays, nearly new discs all round, repaired arches, new oil change, filter change, cam belt change, new plugs, rotor arm
& cap also replacement distributor
& leads, replacement map sensor
& engine temp sensor along with replacement rear brake calipers
& working handbrake, replacement sun roof, new rear exhaust box, replacement front slam panel, replacement front bonnet badge,replacement TPS, new front bumper" TOYOTA" transfer
& replacement bonnet, air filter, coolant flush and new anti-freeze
& bleed plus lots of other bits that ive forgotten but Kevin will no doubt add to, so as you can see we have spent ages getting this car right so this really deserves to go to someone who is looking to get into the wonderful world of MK1 ownership as most of the hard work has already been done, Jinxy
