Air leak gran
Reason why its not there on a cold start up is due to the enrichment on the efi.
basically, theres a shed load of fuel entering and the idle control valve when its wide open.
the engines is expecting an extra flow of air and fuels.
When the engine gets hot, the fuelling is majorly reduced.
when an air leak occurs, its draws it in from there instead of the throttle body
so the engine rises in rpm.
but theres not enough fuel and confusion occurs as the throttle is closed
( throttle position sensor
) and hence your surging engine idle.
Suggest replacing the gasket for the idle control valve for a start
( as its been off
), then throttle body, then the intake manifolds
Basically all the gaskets on the inlet manifold.
Its difficult to tell if theres a leak
( mechanical view
- where air is being pulled through.
It only needs to be a little bit of grit on the surface when bolting up to draw the air in to upset the idling.
Hence
- change all the intake manifold gaskets
- check
/ inspect surfaces
/ casing for cracks etc.
That should resolve the problem.
the idle contol valve has been changed
Was this changed for a new one or for a used one that may have been caked up
??? I've cleaned a few up where they've been stuck open, so cold idling is good as the valves wide open, but then when warmed up, the valves still jarred open
= excessive air being drawn in which will give you that erratic idling.
So recap
Inspect idle control valve first
( strip off throttle body and inspect valve actually moves and not seized
Change throttle body gasket whilst your there, or thin coating of instant gasket will seal it up.
All the above and still no resolution, budget for changing all the intake manifold gaskets.
Have you ever unbolted that top flange
( curiosity
) which is part of the plenum on the intake manifold.
the bit with the bolts
( just in front of the engine lid anchor point
you could try doing that one yourself, unbolt all the nuts and bolts, get some instant gasket, thin coating around the gasket and bolt it back down
I'm 99% sure its an intake drawing too much air issue.
all mechanical, not electronic.
The engines generally don't have a problem like that unless its been disturbed
- like idle control valve removal etc.
Keep smiling.
![Smile :)](./images/smilies/icon_smile.gif)
