[Mk2] [NA] Ign timing after belt change
Just replaced a timing belt on my 3sge, made sure every mark lined up and checked it several times, does a new belt slightly alter the ignition timing as I wacked the timing light on it earlier and it's only very slight out before 10' btdc but it was spot on before the belt change.![](./images/smilies/spacer.gif)
